LPG Kit W/ 2 tanks off of 2F engine
Replacing the engine in my 40 series with something else and have a full LPG conversion to move along. It's been on there for probably 10 years or so but was running just fine up until I pulled it. Current inspection is good until 9/2015 if that's of any use. Will come with 2 tanks, all hosing I could salvage, throttle body, air cleaner assy and the regulators. Essentially everything you need aside from some copper tubing which had to be cut to remove from the vehicle. Showing some age but a sand and paint would clean it all up.
- mudlva
Re: LPG Kit W/ 2 tanks off of 2F engine
what brand and where abouts are you?
Impco Model L, located in Taupo.
