Has anyone used one of these turbo kits before?
https://touch.trademe.co.nz/listing/view/862923513
Not wanting to run large boost say 10 to 12 psi at most
Will eventually get boost compensator and a better turbo down the track
But just want a bit more drive ability for the mean time
Alex
td42 turbo kit
Re: td42 turbo kit
similar. to the one I put on mine go with interal waste gated turbo, there's a lot not in that kit the joiners to the manifold crossover pipe hose clamps oil feed line , oil feed block , you'll need to have oil return to the sump.
there is a lot to do to fit a turbo, with working 8 hour days near three months over winter to fit mine
Re: td42 turbo kit
coxsy wrote:similar. to the one I put on mine go with interal waste gated turbo, there's a lot not in that kit the joiners to the manifold crossover pipe hose clamps oil feed line , oil feed block , you'll need to have oil return to the sump.
Cheers Coxs
Will keep looking for something a bit better
Has anyone made a j pipe adapter to use standard exhaust manifold?
Re: td42 turbo kit
a couple of guys on here have done them , there is nothing wrong with that kit, apart from bits not there it's a starter kit, if you are in no rush to fit it ,buy the other bits over time, then one big bolt up session
Re: td42 turbo kit
Cheers will see how things go
Turbo can wait till after 2" lift, big guard chop and 35s
