Single to double cab
braydenh28
Post by braydenh28 »
Hi all I have a single cab 92 hilux and have spent a lot of money reconditioning engine etc. I am now wanting a double cab and woundering wether it is possable to fit a double cab toy chassis and how much work is required. Has anyone done this or no anyone that has it would be great to hear from you. Cheers
KIWI_TERRANO
Re: Single to double cab
Post by KIWI_TERRANO »
Yes.. You have to fit 2 more body mounts.. Wheel base is 18mm shorter between models
braydenh28
Have you done this before? Apart from the 2 mounts dose everything else line up?
NJV6
Post by NJV6 »
I did it the other way, put a single cab body on a double cab, there are 4 mounts needed to change if going double cab, the ones behind the front doors on the single cab and the deck mounts will need ground off.
I had a single cab and a double cab to measure off, there was no difference in the chassis and wheelbase lengths. The only difference is the cab&deck mounts. I think I did a thread on here of it.
NJV6
Post by NJV6 »
braydenh28
Hay cheers mate
Return to “Tool Shed”
