Wanted sump for 3L surf
- Team Tonka
Putting a 3VZ-FE into a buggy and needing the sump, pick up pipe, and dipstick from a surf 3VZ-F. Looks like they share the same block so hoping it will be a bolt on solution to any oil starvation woes at silly angles. Maybe someone has a tired motor I can grab the bits off? Cheers Andy.
May the force be with you.
- Team Tonka
Re: Wanted sump for 3L surf
Can anyone advise height of surf sump from gasket face to bottom. At least then I can move on with other things until I find one. Cheers Andy.
