Installed snorkel - NOISEY AS F*#K
Posted: Wed Apr 08, 2015 6:50 pm
by RyNoBro
Hey Team
have finished snorkel install on my wd21 finally - has a very strange rotary engine sound (bop bop bop bop bop).
Went for a spin - When heavy accelerating you can here the induction noise which i believe to the norm.
Sounds like a valve opening and closing or someshit - unsure am no mechanic (Sparky).
If anyone has any suggestions let me know.
Re: Installed snorkel - NOISEY AS F*#K
Posted: Wed Apr 08, 2015 6:59 pm
by Crash bandicoot
got a filter in it?, might have a bent valve or broken valve spring /rocker
Posted: Wed Apr 08, 2015 7:03 pm
by RyNoBro
Yeah filters in it - where is that valve? Is that in the bit that goes over the top - labelled turbo ?
Posted: Wed Apr 08, 2015 7:19 pm
by travis2ninja
RyNoBro wrote:Yeah filters in it - where is that valve? Is that in the bit that goes over the top - labelled turbo ?
The bit that says "turbo" is the cross over pipe!
A valve is an internal engine component, you have 8 in the td27, 4 exhaust and 4 intake.
Posted: Wed Apr 08, 2015 7:23 pm
by RyNoBro
Haha yeah no mechanic here -
O so that sounds pretty major!
Yeah when i removed snorkel from air filter housing it makes a similar noise there.
Bugger. Snorkel might be pretend...
Posted: Wed Apr 08, 2015 8:20 pm
by coxsy
bad news most transfer the intake noise. even amp it up for your benefit
Posted: Thu Apr 09, 2015 6:54 pm
by sublimenz
Do what I did and sell the d21 and buy a challenger, they never break down and cost 10k to repair
Posted: Thu Apr 09, 2015 9:58 pm
by slide
What brand snorkel do you have? Any snorkel will make induction noise loud, but the safari snorkel that hugs the roof line (google image search will show what I mean) is louder than most (close to deafening at full noise with window open) . Maybe have a listen to some other vehicles with snorkels to compare?
Posted: Thu Apr 09, 2015 11:49 pm
by RyNoBro
Yes that is the exact one ive installed slide - dammit
Posted: Fri Apr 10, 2015 12:21 pm
by catalystracing
Wait till your in heavy bush and turn it backwards to stop it from being ripped off
