MR2 AW11 Calipers wanted
Hi. I'm after some rear calipers off of an old MR2 AW11 turbo to do rear brakes on my Bundera
Re: MR2 AW11 Calipers wanted
Do you the supercharged AW11? SW20's came out with turbos.
I used SW20 non turbo calipers on my hilux conversion.
I dont know what the difference between the turbo and non turbo calipers.
- mudlva
what is a set worth to ya?
i think ive got a set of a mr2 for a project a few years back but i ended up not using them.
if the coins right i will move all my shat around and see if i can dig them out
The turbo ones have a bigger piston area apparently & they fit the Prado ventilated disc. They are marked 22v
- tomsoffroad
- Flopsie
The sw20 non turbo (16v markings) use a slightly smaller rotor than the turbo model (v22 marking). Both use vented rotors.
The v22 calipars (spelling
) are getting hard to find now tho.
I use a kzj/lj78 rear rotors on hiluxs which works well.
I have the LJ78 rear rotor & that is why I really would like to use the 22v caliper as they match the disc diameter better & I need the truck to stop on 35's for cert & have a half by decent hand brake. My preference would be to put a complete KZJ78 rear in the truck but unfortunately can't afford that
- mudlva
You might be in luck email sent
Still looking. Turns out I was put crook about what they come off. Apparently I want the ones that come off a SW20 Gen3 turbo. Anyone know where I can get some from?
- catalystracing
I have some 16v calipers from an SW20 turbo MR2, what did you use for rotors??churchill wrote:Do you the supercharged AW11? SW20's came out with turbos.
Did they work ok??
Im only using it on my daily and on 31s so not needing the big clamping power to stop big donuts.
How did the hanbrake setup work?
Cheers.
They work well, had to use a proportioning valve to reduce the line pressure and stop the rears locking up before the fronts. They are fitted to a suzuki so the hand brake already had the 2 cables, I just had to modify the cable mounts and get adaptors for the cable pull end.
I used 90 series rear rotors, the diameter is too big so the pads had to be filed to suit.
- catalystracing
Many thanks for that, looks like there is many combos, and you need to be creative to make it work for you
Yeah confused, aw11 or sw20? No such thing as turbo aw11 (at least not factory)
Make an account here http://mr2.org.nz/phpbb3/ and post something in the buy/sell, if you can't find anything elsewhere.
Current: 1992 Toyota MR2 G-Limited with Gen 4 3S-GTE), 1990 Toyota MR2 G-Limited, 1997 Sprinter Carib
Past (only 4x4's due to character limit): '90 Hiace Super Custom Part Time 4x4, '94 Pajero, '93 Pajero, '92 Pajero, '92 Terrano, '91 Pajero, '91 Pajero
