Aotea
Aotea
Anyone keen to sort a play this weekend?? perfer sunday
- mroffroader
- mroffroader
- warlord225
could be
Ok where and when ive got most of the nessary gear like snatch strop,fire puttin out thingy,front tow hooks none on rear and some 6.5 ton shackles as yet and im green as hell doing this sorta thing but we all gotta start somewhere huh
Terrano TD 2.7 and a ssangyong Rexton
- mroffroader
This trip is ON, 10am tomorrow (Sunday) at the gate onwards, if you get lost you can ring me on 027 479 2417 or PRS ch 10, I'll be in the Rugger or the Shiny Red Grand Vitara.
$2 per truck (this covers some beer for Henry which helps maintain our access). BYO Meat (ie sausages and or steak).... I will bring some bread and sauce
very quick drivers briefing at 10.10, basically to say keep away from the moto-x tracks at the top and away from the homestead down the bottom, look out for kids and if you go off somewhere make sure someone is with you in case you get stuck etc
we may be able to go in other areas around there.
Ramp will be there hopefully.....if you need instructions to get there ring me...
PS was anyone up there recently in a pajero? with ORE stickers?, if so can you pls PM me.
Notice the Motorway on the left of the picture. This is out by porirua. Type frances brown ave into smaps.co.nz if you want more detail.
Long, just turn up, you can reverse out of most things, and if you're really stuck, you can climb under and hoop a strop around something solid. I.e your rear axle.
Im not sure if I'll be able to make it tommorow. Hopefully I will be there, even if for a short amount of time. Jerry, is the gate going to remain unlocked?
- mroffroader
- mroffroader
turoa wrote:jumper wrote:i will be there with the carb that does not like hills
Go through the really deep bog then![]()
What happened to your terrano?
yea the terrano that i bought but you took from underneath me...........MWHAHAHAHAHAHA shame u bought it and not me hahaha
mroffroader wrote:turoa wrote:jumper wrote:i will be there with the carb that does not like hills
yea the terrano that i bought but you took from underneath me...........MWHAHAHAHAHAHA shame u bought it and not me hahaha![]()
What are you talking about?
im out
i cant make it guys was changein the front sway bar bushes n twisted off one of the sway bar bolts so untill i fix it im a no go sorry
Re: im out
long wrote:i cant make it guys was changein the front sway bar bushes n twisted off one of the sway bar bolts so untill i fix it im a no go sorry
what do you need a swaybar for
- mroffroader
Re: im out
turoa wrote:long wrote:i cant make it guys was changein the front sway bar bushes n twisted off one of the sway bar bolts so untill i fix it im a no go sorry
what do you need a swaybar for![]()
exactly you dont need them its not even a wof thing your legally allowed to not have one on the rod be careful dont go fast around corners and well see you there at 10am and youl be flexing better than ever without one
A few more pics
http://www.offroadexpress.co.nz/modules.php?set_albumName=album285&op=modload&name=Gallery&file=index&include=view_album.php
microwaved cheese on toast
