twin turboing a V6
mudsurfv6
twin turboing a V6
Post by mudsurfv6 »
on a V6 ( or V8) to turbo it you would need a turbo on each side, right? problem with turbos are the lag, so the answer is twin turbo. ( big and small). right?
question is can you put a big turbo on one side and a small on the other? or would you have to quad turbo it? big and small on each side?
how would best option above ( + intercooler) compare to TRD supercharger? and $. 5VZFE. auto.
Andrew 0272226292.
slide
Re: twin turboing a V6
Post by slide »
Its simple enough to run one turbo either one side with pipe around from other side, or centrally with pipes from both manifolds. Good luck mixing a big and a small turbo as twins. Very hard to keep a smooth torque curve. (hint, search Subaru valley of death). Lag is almost non-existant nowadays. Boost threshold can be a problem if you chose a large turbo, but can be minimised if you need a large turbo. Better to get one suited to what you require, and what you are wanting is the biggest factor of what to choose.
tweake
Post by tweake »
single turbo V engine gets a boot load of lag due to the exhaust cooling down (expansion) on the long exhaust pipe from one side to the other.
there is single turbo V engines (typically diesel) where the exhaust is on the other side of the head and turbo is mounted in the V of the engine.
one turbo per bank ie one each side is much the norm.
dual turbo (as in one big and one small) your looking at sequential, which is difficult to get right, or compound which is only really needed if your chasing 40psi plus. on a V engine thats per bank so it would be quad turbo.
mudsurfv6
Post by mudsurfv6 »
just been throwing ideas around with a mate. be a while away before I get onto engine mods, too much other stuff to do first. but I'm always thinking about different ways of doing things and making a plan in my head, no doubt will change over time.
slide wrote:what you are wanting is the biggest factor of what to choose.
money is the biggest factor. not exactly sure what I'm wanting/needing yet. just good to know what can and can't be done. trying to compare against supercharger.
Andrew 0272226292.
Crash bandicoot
Post by Crash bandicoot »
what breed of engine are you thinking of turbo charging apart from a v6/v8 obviously
mudsurfv6
Post by mudsurfv6 »
Crash bandicoot wrote:what breed of engine are you thinking of turbo charging
mudsurfv6 wrote:5VZFE. auto.
vzn185 surf.
Andrew 0272226292.
mudlva
Post by mudlva »
Thought about throwing the 3.4 out and chucking in a 4.0 v6 out of a mid 2000s prado.
250hp and 380f/pd of toque. Just about 1/2 again inprovement from what youve got and it would fit in quite nicely
Crash bandicoot
vzn185 surf.
TRD did a supercharger kit for prado eh? was for the quad cam one though.
or your really want to go turbo.?
mudsurfv6
Post by mudsurfv6 »
mudlva wrote:Thought about throwing the 3.4 out and chucking in a 4.0 v6 out of a mid 2000s prado.
haven't thought about it. done a few engine swaps and don't feel like doing another. worth thinking about though, is the mid 2000s prado front drive shaft on the left or right?
Crash bandicoot wrote:or your really want to go turbo.?
mudsurfv6 wrote:how would best option above ( + intercooler) compare to TRD supercharger?
mudsurfv6 wrote:just good to know what can and can't be done. trying to compare against supercharger.
been told twin turbo option would be cheapest but probably not as good an option as sc.
Andrew 0272226292.
Crash bandicoot
how hard would it be to take the lower half of the (valley cover) of the toyota v6 and mate the top half (runners) and eaton supercharger from a vy series II calias and run a 1 & 3/4 inch pulley.
just thinking outlay versus return.
just asking as that TRD one above looks suspiciously similar to the eaton that was on my VY.
The WEHI
Post by The WEHI »
theres a surf on trademe that comes with all the supercharger stuff for a 5vzfe not installed its had the back cut off
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
The WEHI
Post by The WEHI »
(027 788 1046)
mudlva
Post by mudlva »
just had a look. Left hand side.
mudsurfv6
Post by mudsurfv6 »
The WEHI wrote:theres a surf on trademe that comes with all the supercharger stuff for a 5vzfe not installed its had the back cut off
just paid for the supercharger. so that solves that decision.
Andrew 0272226292.
The WEHI
Post by The WEHI »
:mrgreen:
(027 788 1046)
mudsurfv6
Post by mudsurfv6 »
problem is I just spent the $1000 I was going to use to buy some 35's so I can do the sas. now gotta save up again.
Andrew 0272226292.
just watch a nismo gt Lm car video ,1250 hp, twin turbo front wheel drive V6
anything can be done if you got the cash,
