Mitsi 3.5 auto choke/idle stepper motor needed
Smurf
Post by Smurf »
Auto choke/fast idle/idle stepper motor set up from mid 90s 3.5 litre Pajero required to keep the Sister in Law happy.
NJV6
Re: Mitsi 3.5 auto choke needed
Post by NJV6 »
Idle stepper motor? They get gunked up and can be cleaned easy enough with carb cleaner, they are mounted under the throttle body, I have had to clean mine before I put a catch can on it, it was idling a bit funny and stalling from memory.
Smurf
Post by Smurf »
NJV6 wrote:Idle stepper motor? They get gunked up and can be cleaned easy enough with carb cleaner, they are mounted under the throttle body, I have had to clean mine before I put a catch can on it, it was idling a bit funny and stalling from memory.
Glenn this one idles fast and has on and off for years, now is permanently idling around 2200 RPM. it has been cleaned out a few times but has issues still
NJV6
Re: Mitsi 3.5 auto choke/idle stepper motor needed
Post by NJV6 »
Oh right, it's really high! Good luck. I seem to recall the 3.0 ones being te same but can't confirm this.
Good luck.
Team Tonka
Post by Team Tonka »
I'll have one somewhere, $40. Cheers Andy.
May the force be with you.
Smurf
Post by Smurf »
Team Tonka wrote:I'll have one somewhere, $40. Cheers Andy.
PM sent. Cheers Andy
nztimr33
Post by nztimr33 »
if the battery has gone flat or been disconnected mitsi need to relearn idle - just a fyi , dissconnect battery for 5 mins , put it back on and let it idle for 5-10mins with no load i.e air con , steering wheel straight , then drive it might be all it is - worth a try anyway :)
