tyre pressue
tyre pressue
can anyone advise the correct 'everyday' tyre pressure for 31x10.5x15 Firestone RMT Tyre????? Ta
I travelled the road less travelled now where the heck am I!!!
One school of thought is to use the max load @ pressure markings on the tyre sidewall, work out what percentage of max weight you have on the tyre and use that percentage of the max load pressure (does that make sense).
ie max load @ pressure marking on tyre (BFG 315/75R16 in this case) is 1450kg @ 50psi. If you figure you have 870kg on the tyre (60% of max load) then run it at 30psi (60% of 50psi).
Remember that a tyre 10% under infalted has much less grip on the road than a tyre 10% over inflated.
- warlord225
4WDbits wrote:One school of thought is to use the max load @ pressure markings on the tyre sidewall, work out what percentage of max weight you have on the tyre and use that percentage of the max load pressure (does that make sense).
I should find out what my zook actually weighs then...
Tyres are 2100lbs @ 50psi each (from memory)
The net says the curb weight is 2332lbs
so assuming the weight is evenly over the four tyres thats 582lbs in each tyre (and 28% of max load), therefore i should be running them at around 14 psi
