rocklobster transfer help
Posted: Fri May 08, 2015 4:37 pm
by mattax100
Hi guys I'm after some advice on who can machine the needed parts for me for the "rocklobster" mod
Any input would be great thanks canterbury area
Re: rocklobster transfer help
Posted: Fri May 08, 2015 7:56 pm
by lilpigzuk
If you don't have any luck down there, I can give you the name of someone up here in Auckland
Posted: Fri May 08, 2015 8:51 pm
by mattax100
Hi yes that would be great thanks they done 1 before?
Posted: Fri May 08, 2015 11:43 pm
by Swamped
I struggled to find someone in Hamilton and the pricing all up was gonna be comparable to running an aftermarket gearset. I went with new gears. Lilpig won't put you wrong though if you continue with a rocklobster.
Posted: Sat May 09, 2015 8:01 am
by ChurchurDan
Try Justin Neil engineering in Brooklands or Eagle engineering in Waipara.
Posted: Thu May 14, 2015 4:51 pm
by UBZ
Last time I Checked it was cheaper to just buy the 4.16 counter gear from Lowrange Offroad than have the gears machined , pined and welded . Then use that with your 410 and 413 parts
3 Cutting heads were consumed machining my gears
I can give you contact in Auckland too if your stuck . Howats in Wellington would be more than capable too.
