Commodore V6 Auto to isuzu transfer
Ashohman
Post by Ashohman »
Commodore V6 Auto to isuzu transfer does anyone have any links to a tutorial or walk-through to mating these two together just trying to get an idea of what ill need before i start this project.
thanks Ash
mud_slinger
Re: Commodore V6 Auto to isuzu transfer
Post by mud_slinger »
head to clubisuzu.com be heaps of info on there
needs more curry
0272593533
pruggerdore
Post by pruggerdore »
Re: Isuzu transfer case onto series 1 Holden auto
Postby pruggerdore » Mon May 26, 2014 1:01 pm
The one I have used is from the 3.1 auto bighorn. auto has a lower first gear than manual. believe mu 3.1 MU will do it too. A particular year mu has a smaller diameter front driveshaft making trans sump clearance better but still not great for suspension travel. some transfers are part of the box and not separable.
Adapter... remove trans tailshaft cover. cut 50mm off shaft. There is a groove there telling you where to cut. make a plate to match trans bolt patern. A plate to match transfer box bolt pattern. put a piece of 100mm pipe or box section between the 2 and weld. Done.
