Im having trouble with my rear setup. No pressure at the calipers. Bled them like normal. Nothing...
I have had a small amount of success by pumping the hell out of the pedal and the pressure would hold but be gone if I released the pedal and tried again
I pulled the master cylinder out and flushed it. Bench bled it and it worked fine. put it back in and had no pressure again. So after checking everything. bypassing fiddle brakes etc and spilling a shitload of brake fluid EVERYWHERE Im non the wiser.
My only conclusion is that the master cylinder is stuffed. If there was a crook fitting or if the caliper seals had gone then they would be leaking fluid. Right?
No pressure and no leaks = bypassing master cylinder?
I feel like an idiot not being able to bleed my brakes but I have been chasing false hope all arvo. I have given up and started drinking haha
