Yet Another Suspect Noise - From Gearboxc I think
For all Nissan related topics
wjw
Post by wjw »
Hey all,
I have a new problem :) I have a strange squeling noise coming from either the Gearbox or Transfer Case (I think) when accelerating in 1st, 2nd and 3rd.
Any ideas?
Also as I have a tooth missing on my reverse I might just replace the gearbox, any ideas where I could get a gearbox for a 1986 Nissan/Datsun 720 4wd (matting to a Z18 (s) 1770 sometimes reffered to as an L18), if not any ideas on what I would expect to pay for reconditioned one?
Oh and anyone know where I could get a front diff?
Thanks,
Bill
Who knew Prados could fly?
tomsoffroad
Flopsie
Post by tomsoffroad »
Bad timing dude. I got a mate in Ashburton who has a garage full of these, quite handy as I have an 84 720, unfortunatly he is in Aussie until end of September. If you are still looking then let me know.
As for the squeal, mine did it to, it wasn't the gearbox or transfere though, it was the p/steer pump belt. It was strange cos it only did it in 1st and 2nd.
Now that I think about it there is a guy around the corner with one sitting in his back yard.
(back yard wreaker) I can ask him what he wants for the front diff if you want, not sure whats in it or what the ratio is though. Think it's a petrol.
Cheers Thomas
wjw
Post by wjw »
Cool Thanks, It could be power steering I've been having problems with the Reservoir leaking from the outlet hose and have been trying in vain to re-seal it, what happens when they dont have enough fluid??!?!?.... I'll check tommorow, strange thing is it sounds like its coming from somewhere around the transmission tunnel. Ahh well... I should really buy that 4wd hack I keep thinking about...
pinky
power steering
Post by pinky »
hi the easiest way to check this squel ( if you suspect power steering ) is to remove the drive belt to the pump ( this will not cause any damage ) and go for a test drive and if the noise is gone you know where to start looking ofcourse the steering will be heavy but this is a good way to check for power steering problems thanks pinky ps . keep me informed of the outcome .
tomsoffroad
Flopsie
Yep i'd buy another one if its for a toy, mine is only a work hack, the old diesels rattly as hell but seems to be very reliable.
The old 720's not much more than a car with ground clearance when it comes to 4wding :D
wjw
Post by wjw »
Well its not any of the belts, checked them all this morning.
But this evening is a different story... on my way back from Alex (to Wanka) the noise disapeared, then went kirch bang, clatter clatter..... and well the gearbox shat itself. :shock: All the oil from the gearbox decided to exit through the now blown seal between the gearbox and bell housing (Clutch plates) . Managed to get most of the way home in 2nd by starting in 5th and working backwards, as clutch wasnt working, then a mate came out and towed me back with flashing yellow work lights & all... so if anyone say a huge Delta truck with all its lights going towing a truck, that was me. Oh and he decided to tow me round town too.... just for the embarassement factor... ahh well.... mates :roll:
So it looks like I'll be down the garage tommorow taking it to bits and seeing exactly what went wrong. Ahh well...
So first check the belts, if that doesnt solve the problem BEWARE.....
I'll let you know what the final outcome is once its in bits. but I suspect I need a new seal, maybe a new bearing?!?!? as I'm guessing theirs one in there somewhere...
tomsoffroad
Flopsie
Bugger
wjw
Post by wjw »
ok well its the gearbox and the concencus is to buy a reconditioned one (2K+) which I can't afford so I'm looking for second hand ones... which I might just be able to afford....
wjw
Post by wjw »
So questions....
1. Any ideas on the price for a 2nd hand gearbox?
2. If I strip it down and work out whats buggered, would that be cheaper?/??
mike
Last minute Mike
Post by mike »
Well you have to take it out anyway and if your going to get another replacment just whip it apart because it won't matter. I'm guessing that a bearing seized and spun in the housing on one of the shafts or something similar. You'll soon see whats wrong when it's apart :wink:
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
pinky
shit happens
Post by pinky »
hi WJW can you give me any part No and model No as i may have a complete damaged box as well and you may be able to make 1 out of 2
tomsoffroad
Flopsie
wjw
Posted: Fri Jul 30, 2004 2:36 pm
So questions....
Hi
Found a second hand 5spd, part no FS5W71B HF48. $200+freight.
Its in Oxford Nth Canterbury, its off a SD23 diesel, I'm not sure if they are the same, check the part no's and get back to me.
Thomas
wjw
Post by wjw »
Sorry guys, was my Birthday on Friday and ended up being wasted all weekend :shock: But will hopefully get the box out this week....
thx,
Bill
tomsoffroad
Flopsie
Happy Birthday dude :D
wjw
Post by wjw »
Cheers bro,
Well managed to spend a couple of hours on it today.... got the primary driveshaft off and the front driveshaft.... am stuck trying to take the exhaust off now.... damned bolt wont undo where the exhaust joins the manifold :( ah well, gonna get a hacksaw onto it tommorow.
Had a chat with the dudes down the garage today (who are trying to price a replacement) and they say I have a non-standard gearbox.... hrm.... Any ideas on whether the part number is printed on it somewhere?
wjw
Re: shit happens
Post by wjw »
pinky wrote:hi WJW can you give me any part No and model No as i may have a complete damaged box as well and you may be able to make 1 out of 2
Will get you a part number as soon as I can find it ;)
If it helps its a 5speed box matted to a Z18 1770 with a seperate transfer box.
Thanks mate ;)
Bill
tomsoffroad
Flopsie
The gearbox/transfere numbers are on the right inner guard by the fire wall if this helps.
wjw
Post by wjw »
cheers will look under the mud & oil tommorow....
wjw
Post by wjw »
Okay details I've mustered so far:
Type - L-DGY720
Model - UDGY720TFDX2
Engine - Z18 (S) 1770
Trans - FS5W71B
Axle - HF48
Looks like the one Tom ;) hopefully you see this within the next hour.... otherwise, how much to ship it to Wanka?
Thx
Bill
wjw
Post by wjw »
Is there a nack to getting these damn things out????
tomsoffroad
Flopsie
Dunno haven't had to pull mine out yet, fingers crossed I won't have to for a while either.
I'll suss out the freight tomorrow.
I have been told that it takes longer to pull out the driveshafts than it does to pull out the gearbox. Is this true? :D :twisted: :twisted:
I'll PM you tomorrow night with the details.
Thomas[/quote]
wjw
Post by wjw »
It looks like I need to take out the front diff too... thats makes:
Primary Driveshaft
Front Driveshaft
Exhaust
Transfer Case Rock Guard
hmm doesnt sound like much in list form.... ahhhh
PS: When I spoke yo local mechanic guru he said it'd be a nightmare and would take 1 1/2 days!!!!
tomsoffroad
Flopsie
So what you are trying to say is that by the time mine goes splat, you'll be an expert on the 720 gearbox and will come up and do mine :D :D :D
I spoke to a couple of truck companies this morning about freight and am waiting for them to get back to me, I'll phone them tomorrow if I haven't heard by then.
Thomas
wjw
Post by wjw »
I will be ;)
just have to rotate the front diff 90 degrees and it should drop out... :)
tomsoffroad
Flopsie
Hope its not to hard to do, cos if you want this gearbox up here then I would say that I will have to pull it out myself :(
wjw
Post by wjw »
Oh bugger... so its in the truck!!!!! Hmm.... I wreckon in total it would take about 2 hours, if you had a properly equiped workshop, I've had problems with seized bolts, welded nuts all sorts... have had to cut two bolts so far....
mike
Last minute Mike
Post by mike »
I've found from experience that having a small gas plant saves so much time and stress. Bolts are cheap, shrinks arnt ;)
Mike
1994 Toyota Surf
wjw
Post by wjw »
mike wrote:I've found from experience that having a small gas plant saves so much time and stress. Bolts are cheap, shrinks arnt ;)
Mike
I thought about that, but the worst bolt was next to impossible to get to.. I could only just get to it with a 10mm x 200mm saw blade... :shock:
tomsoffroad
Flopsie
Hmmmm. Oh well at last I don't have to worry about the tansfere box, it already out.
Should make it a tiny bit easier :lol:
wjw
Post by wjw »
Well the gearbox is now out... just need to open her up and see what's buggered...
how are those shipping costs going?
Thanks,
Bill
