welding bench top WTD
- drive it ...
Bought a cheap n nasty little arc welder a couple of weekend back to have a crack at melting some metal. Have set the bench on fire so I think I better set up a welding table. Anyone got a bit of steel plate say 600 x 600 x 3mm or whatever. Bigger is better. Can swap 4.8 toyo 8" diff head with couple teeth gone on crown wheel - otherwise good. Christchurch area.
Re: welding bench top WTD
Can supply some 3mm, can cut and fold it as well, don't need a Toyota diff tho.
