So I've got a small oil leak coming from between the block and the valve cover (1hdt), fairly sure it's coming from there anyway. Is the valve cover gasket difficult to replace? It looks like it wouldn't be too hard to do.. Any advice appreciated
Cheers.
Replacing 1hdt valve cover gasket?
Re: Replacing 1hdt valve cover gasket?
nope..short answer..
- rodeorunach
- Driver/Navigator
I replace the gasket on the 80 series getting the cross over pipe was easy there was a bracket on the fire
Wall for the brake pipes was in the way didn't have a small ratchet to move it so had to lift the rocker
Cover up enough and slip the gasket in to place
