Wider track for on road
Posted: Mon Jun 01, 2015 10:06 am
by wattsy
My Escudo is a 97 SWB 1.6 with Factory 16inch wheels, I would like a little bit more stability for on road use and as the tyres will soon need replacing wondering what would be a good solution? Don't generally use off road much I have asked previously and it sounds like 15's would fit but a cheap option may be off a V6 one if they are a slightly wider rim/offset.
Thanks for any help
Re: Wider track for on road
Posted: Mon Jun 01, 2015 11:48 am
by zukmeista
If yours is a 1600cc you should be able to fit 15" rims without modifying anything but would pay to try a rim before you buy. Where in NZ are you?
Posted: Mon Jun 01, 2015 12:27 pm
by wattsy
Manawatu. They are factory 16inch rims 215/65/16 tyres. Seen a few with them on seems its around the 97 model that they changed.
Posted: Mon Jun 01, 2015 2:38 pm
by churchill
The grand vitara rims (V6, I don't know about the 4 cylinders) have a larger offset so will give you the wider track you want.
If you are going to take it offroad you might have some guard rubbing but I can't confirm this.
Posted: Mon Jun 01, 2015 7:46 pm
by mudlva
Drop the suspension and harden it up.
Throw the rims and run a set of 19s or bigger with low profile tyres.
Thats what lads do to get there weapons to corner better.
Just remember that 4bys arnt sports cars
Posted: Tue Jun 02, 2015 9:35 pm
by wattsy
Its not a sports car, I have had two Surfs in the past with all the mods, this is just a little work hack. It just seems a little unstable at 100 so was thinking a slightly wider track may help.
Posted: Wed Jun 03, 2015 12:04 am
by Swamped
Pretty sure the vitaras track width is similar to a hilux. My past vitaras swb and lwb have felt pretty stable with minimal lean before the ass slides out. Must be driving like an animal or the sway bar bushes might be buggered if you feel like stability is an issue 8)
Posted: Wed Jun 03, 2015 4:19 pm
by KIWI_TERRANO
Dont go to 15s if you want better handling
16 have less side wall get a fatter profile tyre and check ya air pressures
Posted: Wed Jun 03, 2015 6:50 pm
by Smurf
I'd start by looking at bushes first, sway bar, Suspension arms, panhards if fitted. even sloppy shock bushes may be an influence, or even buggered shocks.
Posted: Wed Jun 03, 2015 7:04 pm
by wopass
:shock: :o :shock:
since when!!??
dirty lies!!
:lol:
Posted: Wed Jun 03, 2015 8:13 pm
by mudlva
wopass wrote:
:shock: :o :shock:
since when!!??
dirty lies!!
:lol:
Ok ok
Sorry ben i will refrase
O.e 4bys arnt sports cars
Posted: Tue Jun 09, 2015 8:47 pm
by crzyfl
You could Hagen widen the front, just need spacers and a stub axle made up.
Posted: Wed Jun 10, 2015 11:08 pm
by Fwb2700
If you need to get for 15s I'm in palmy and have a few as working on my sj project welcome to come round and use them as a test fit
