People who have replaced front diffs - Is there a trick to getting this out? have read some people saying you undo the diff crossmember bolts and the two bolts on the front cross member and it just drops out but mine seems to bind up on the torsion bars or the bottom of the motor (diesel). really dont want to have to remove torsions just to get out diff but if I have to I have to.
Cant even remove the front crossmember as two of the bolts are locked in by the lower control arms. Any tips thanks
