70 series diff
70 series diff
Are the the front and rear diff heads interchangeable on a bj74? Thanks.
Re: 70 series diff
depends on if it a full floater or not.. but generally yes.. if full floater
- mudlva
Re: 70 series diff
Just to expand on above the front can go into a semi float rear unit but you will need the spacing block and c clips.
Any rear can go into the front except for cable locker units. They need special half axles
Re: 70 series diff
Thanks very much for your advice guys, yes its a full floater. Cheers
