new to zooks
For all Suzuki related topics
drewz1
new to zooks
Post by drewz1 »
Hi guys new to zooks needing some spring advice I have just recently bought a 1990 Suzuki escudo short wheel base my question is it has been lifted seems the wrong way at the front the springs seem to big at the top to seat in properly and they are rubbing on the bump stops making a horrible sound what is the best option to fix this should I buy proper Suzuki springs or will the 1600 long wheelbase ones make a difference??
Any advice would be appreciated as im trying to get the old girl road legal
thanks guys
COILY
Re: new to zooks
Post by COILY »
LWB ones will give you about 30mm of lift in a SWB or buy new raised ones. Its always best to have the right part for the job.
drewz1
Re: new to zooks
Post by drewz1 »
Thanks for the advice just decided to do it right and bought brand new dobi sport heavy duty springs 40 mm lift so ill be busy this weekend fitting those
Smurf
Re: new to zooks
Post by Smurf »
drewz1 wrote:Thanks for the advice just decided to do it right and bought brand new dobi sport heavy duty springs 40 mm lift so ill be busy this weekend fitting those
what did they set you back, I am in the same position as you, having just bought a 3 dr for my kids
Swamped
Re: new to zooks
Post by Swamped »
Sounds like someone might have done the "cheap vitara lift" One model of spring people use is too large to seat on the upper properly. It can also mean the brake caliper binds on the spring. The other components used seem to work well (except the front shocks) because they seemed a bit short on the truck I did the lift too. Doing it again, I'd do the cheap lift on the rear and proper parts up front if not proper lift parts all round.
drewz1
Re: new to zooks
Post by drewz1 »
They cost $385 for the springs there is a guy on trade me that sells them they are brand new too
Return to “Suzuki”
