hello all
just wondering how much effort and cost would it be to replace a steering box on a suzuki escudo ???
thanks
power steering
Re: power steering
Rocky road sells a Toyota kit,
Low range sells a TC kit.
Not many TC boxes around in NZ, but looks like a simple job
DISCLAIMER
Re: power steering
Drop out the radiator and start spinning bolts, Cracking the steering off the pitman arm will probably be the hardest part.
I have the same task soon, fitting power steering set up in place of manual box in our newly acquired Vitara. Half day first time around I am guessing for a straight swap, mine I am putting aside the weekend as I have all the pump/hoses etc. to fit.
Re: power steering
Smurf wrote:cracking the steering off the pitman arm will probably be the hardest part.
Still haven't figured this out. I don't want to go too crazy on hitting it because I don't want to damage the PS box...
Re: power steering
Pitman arm puller or press heat and hit with hammer. mine took press heat and hammer and came free with a bang.
