what is the ratio of your transfer case
i am asking as on the weekend when i was out playing with some rough trucks the comment was made that i could travel very slowly so i drove in top gear in both high and low range to se what the difference was from what i can work out my low box is about 2:1 just roughly just wondering what is normal on other wagons
- Moriarty
Ssangyong Korando
2.9 TDI
As near as I can judge, just driving at a fixed engine speed, the difference between hi and low, seems to be 4:1.
Bloody owners manual is inconclusive and not terribly informative.
EDIT:
Found an online manual. AT LAST!!!
transfer box ratio is 2.48:1 - 4.73 LSD
2.9 TDI
EDIT:
Nissan safari/patrol
2.02:1
Which is not low enough esp when you fit bigger tyres,with 35's in low range I can cruise at 55 Km/h,have been as high as 85 Km/h still under 4000rpm and that's not taking into account speedo corection with the lager tyres.Its a auto which has a taller overdrive than manual.
80#-100# Toyota landcruiser
2.488:1
Shane
2.02:1
2.488:1
Shane
adventures_more
adventures_more wrote:can you get crawler low gears for a toyota series 70 T/case ?
http://www.marlincrawler.com/htm/transfercase/gears.htm
You need the transfer case model # but I would think so
Who knew Prados could fly?
adventures_more
adventures_more wrote: the dual t/case looks impressive , wonder how they bolt together ?
Plenty of guys on here with dual transfer setup. If i was building a new rig it would be very high on the list. They make life so much easier when you need to really crawl up or around something.
- hosehustler
adventures_more wrote:cheers for that , Shikes , marlincrawler have heaps of toyota gear , may have to get a low set when i rebuild my T/case sometime soon. the dual t/case looks impressive , wonder how they bolt together ?
http://www.marlincrawler.com/htm/transf ... r_inst.htm
I hate signatures
