Kzn 185 open diff to kzn 130 lsd
Looking at putting lsd diff out of knz130 surf into kzn185 will it bolt straight in or is it not compatible???
Re: Kzn 185 open diff to kzn 130 lsd
straight swap.
Sweet thanks
is it a known working lsd? the reason i ask, is that those LSDs get a bit of wear and start open wheeling real easy, so you could technically buy a LSD, install it, and be disappointed with the results. They aren't expensive to be tidied up( or tightened?) but will never be as positive as a aussie locker or a eaton Tru Trac. just saying.
good point blakenz
a torsen/truetrac or lunchbox locker will be better and possible for not much more dollars.
http://www.4wdstuff.co.nz/lockers/toyot ... -tt913a610
http://www.4wdstuff.co.nz/catalog/toyot ... ux-lockers
Yea it was a good factory LSD my brother rolled and wrote off his kzn130 and bought a 185 put it in yesterday works a treat
