UBS69 Big horn 3.1TD manual. 305 genuine kms. I have owned this for 5 years and it's time for something new.
Very reliable. Serviced every 6 months. Wof only 2 weeks old.
Front and rear auto lockers with 4.55 gears. Manual hubs. Electric rear swaybar disconnect. 2in OME springs and shocks. Ball joint flip and low profile bump stops. Rubber flares. Side bars. Front bar. 12000lb Runva winch with dyneema. Two hooks front and rear. Snorkel. Twin batteries. Massive radiator with AU falcon electric fans. Catch can and egt removed. Onboard air with tank and gauges. Temp, boost, EGT and volt gauges. Rear storage drawer system and cargo barrier. Heavy duty tierods and adjusters. Belly pan. Removeable rear towbar hitch. Front light bar and rear reverse light.
Truck has been maintained well and gets anything needed. Most of the front end has been rebuilt. Fluids and filters changed often. Rebuilt alternator and starter, ball joints, bearings, pads, upper arm bushes and panhard bushes. Replacement power steer pump and high pressure line and seals. Driveshaft ujs. All water hoses.
Interior is very tidy. Electric windows and central locking and electric mirrors. Four large rubber mats. Led interior lights and under bonnet strips. Spare cvs, tierods, drag link, lights and mirrors and an alternator.
Truck goes very well and can keep up with anything on 33in tires. Truck has been used about once a month for club level trips and has some body damage mainly on the drivers side. This hasn't posed an issue for wofs but some body coloured paint might tidy it.
Release bearing is noisy when cold and the glowplugs need to be double glowed during winter. Starter solenoid is getting worn. Ultra reliable however, just being upfront.
Comes on 33x12.5 Hankooks on 15x8 white spokes with a 33in spare. Also available are some 33in silver stones on bead locks.
Cash only, no swaps unless it's a diesel Range Rover, Discovery or double cab 110.
Will get pics up shortly
FS Isuzu Bighorn club truck
Re: FS Isuzu Bighorn club truck
Somebody should get this. Really well setup with all the work done to a high standard.
Real capable truck with strong diffs and hard to find in manual
Someone should buy your truck before mine!
Hi Mate, Whats the price and got any pics available? Also, where in the country are you located?
Alex
Alex
Hey bud.
Location is Kapiti. I am looking for 7k ono but can take bits off to get it to the price needed.
I am having trouble posting pics from my tablet - if you post or pm me your address I will email them.
Hi Mate,
Sent you a PM with my email address, if you can flick through some pics and details that would be fantastic.
Alex
Alex
Didn't get your pm so pmd you
Matt
Matt
Matt
Matt
