Toyota Auto's
brakes-shocks-lockers-etc
wjw
Toyota Auto's
Post by wjw »
De-Ranged wrote:hmmm what do they come out on....
Theres the A343F and A343H in surfs, F and H denominate different transfer cases, which you aren't interested in. A343F is also in cruisers
The transfer case options dosn't worry me I'll be looking at dual casing it anyway for crawling with G52 transfers (need to use them for the pto access port)
A343F from A cruiser or Prado has the PTO plate on it and is usable if you have the gear!
you don't know what the shaft size and spline count is on the gearbox output to the transfer ?? :lol: I know its a bit obscure I'm still working out how hard its gona be to mate this into what I've got
Off hand no, but I'm picking up another A343 on Wednesday, Hilux one with centre output, transfer case is going into a jeep, main box is going to be a spare for me. The guys who checked out my auto found some 4mm metal shards in the bottom... not good. A343F with history that had done 68,000KM's cost me $320 all up including delivery from Gisborne.
If I haven't replied on here with the spline count by next week remind me. Should be splitting it later in the week when Rick gets back from Hols.
Also if you stick with an A340, make sure it comes from and RZ Supra ie Twin Turbo model. They have stronger valve bodies than the standard ones to handle the extra power. Good to over 400BHP as standard if you believe the US sites.
Bill
Who knew Prados could fly?
wjw
Post by wjw »
Just had a quick google. Found this:
I wouldn't recommend the a43de. That transmission is probably not the best choice since the thing was never built to handle big power. It'd probably work fine since hey, it's a toyota, but I think you'll be much better off with at least the A340E which was built to be behind the 5m, 7m, and 7mgte.
Sounds like its the same as the 2JZ. I would suspect that the following will work:
A340e - Cressida --- use A343F/H or A340...
Bellhousing that came with the 5M, make sure its an auto bellhousing.
Should all bolt up then. The only potential issue, when I was researching the 2JZ was that I may have needed to change the input shaft and oil pump over. The internals on the A34x's are almost identical. Turns out that it was fine. Input shaft was same length and spilne count as the 2JZ.
I had
A343F with 1KZ-TE
A340E with 2JZ-GE
Took bellhousing from 2JZ, Torque Convertor from 1KZ (Both the same but 1KZ in better nic) and the A343F from the Prado... all works a treat... well almost, just need a speed sensor for the ECU, but thats another story
SupraSurf
Post by SupraSurf »
The A34X's and R15X gearbox's have 23 spline outputs, the older G52 / W56 transfercases have 21 spline inputs.
You can get 23 spline input gears from the US or make a coupler using 1/2 23 spline and 1/2 21 spline with a sleve over the top if you want to go duals.
The 5M auto bellhousing won't fit the A34X auto's you'll have to get a 7M auto bellhousing.
dazza85
Post by dazza85 »
Hi Bill,
Am I reading it correctly ... that you can do a mod to the electrics that alows you to select gears manuley ??
I have a '91 surf with the 4 speed Auto
How could I get a copy of the wiring mods to do this ??
Thanks for your time.
De-Ranged
Post by De-Ranged »
:roll: :lol: :lol: remember my work of art bellhousing guess what the motor side was from....
thanks for the heads up mike.... I'll start looking
Cheers Reece
De-Ranged
Post by De-Ranged »
Good to see some one else from the bay on here
have a look at this post on Pirate its for a plug in box that lets you do what were talking about
Pirate Thread
You might have noticed a mates truck round town Black Surf with "Friday Racing" stickers :roll: likes to drive it with his $imex'$ on
anyway his truck has had the mod
Cheers Reece
wjw
Post by wjw »
Okay...ready... A343F from Surf:
All the detail re the output shaft to the transfer.
30.52mm diameter to outside of spline tooth
23 teeth
Spline length 22mm
76.8mm from edge of flange to end of output shaft
flange 120mm diameter.
De-Ranged
Post by De-Ranged »
:shock: :lol: Hey Bill just had a really dumb idea :twisted: whats the length from the front of the bellhousing to the drive flange on the transfer case
Cheers Reece
wjw
Post by wjw »
We've split it now, I'll email Rick and get him to measure the T/C...
Bill
De-Ranged
Post by De-Ranged »
I think I might be onto something...
A343 auto with manualised controls going into a CF Bedford Van going into a divorce Nissan transfer case
the CF box gear ratios 5.61, 2.97, 1.58, 1.0. Rev 6.0.
Short :D Tough as, these things were built to move big loads
oh and with 4.3 diffs crawl ratio is 175 to 1 :shock: :lol: and I get to run a pto winch :D :D Might look at a cruiser case as they are less reduction than the nissan not like I'd need that much
Cheers Reece
wjw
Post by wjw »
Blimey.....havent heard back from rick yet :(
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
wjw wrote:A343F from A cruiser or Prado has the PTO plate on it and is usable if you have the gear!
what cruiser has the A343F? prado would be the kzj? did all the kzj prado A343F trans have a pto plate?
trying to fit up to vzn185 surf with A343F trans, but want a pto.
Andrew 0272226292.
kbushnz
Re: Toyota Auto's
Post by kbushnz »
The pto part has to do with the transfer case....
The Early prado's (square ones) in either the 2.4L engine or 3.0 (2LTE, 1KZTE) both sport a 70 series transfer case.
This goes for the auto and manual.
The later Prados with full time 4WD do not have the same transfer case....
All the early Prado's with Auto's use the same A340 style trans...
Now the only issue you will need to watch is the transfer case shaft outputs need to match the surf.. I think the rear of the surf its in the middle whereas the Early Prado (with the 70 series transfer case) has it on the right hand side.
Also the Early Prado transfer cases will need to have the PTO gear and spacer installed.....Never came out as a factory option....
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
kbushnz wrote:Now the only issue you will need to watch is the transfer case shaft outputs need to match the surf.. I think the rear of the surf its in the middle whereas the Early Prado (with the 70 series transfer case) has it on the right hand side.
do any of the prado auto with pto have output in centre? that would bolt up to the surf bellhousing?
or a transfer with centre output that has pto that would bolt up to the surf trans?
or any cruiser transfer that is centre output and pto that could bolt up to surf trans?
or the complete cruiser setup with pto bolt to surf bellhousing?
kbushnz wrote:Also the Early Prado transfer cases will need to have the PTO gear and spacer installed.....Never came out as a factory option....
that could be done when all in truck? or before?
Andrew 0272226292.
Big
Re: Toyota Auto's
Post by Big »
Any A series auto will work with any bellhousing, its just the transferbox that differs.. ie , landcruiser box with xfer are duel drivers side drop with pto on the xfer so you can run one,, the hilux xfers don't have a pto output plat on the xfer..( not totally sure here ) but are centre rear and passengers drop to front.( no good for landcruiser and are also not as strong)
The Autoz came out of a huge amount of vehicles and 4x4s so just need to find a strong one like a 1jzgte or 2jzgte from memory these are factory very strong, or jeep, mitzi, etc etc they just variants of the Asian warn auto. I did a huge amount of research into this when I was getting into my 1uz swap about 10 years ago. There is a post on lextreme that I made that has a list of all or most of the autos compatible with each other.. Help that helps..
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
Big wrote:There is a post on lextreme that I made that has a list of all or most of the autos compatible with each other
tried finding it but no luck. search what on the site?
Big wrote: landcruiser box with xfer are duel drivers side drop with pto on the xfer so you can run one,, the hilux xfers don't have a pto output plat on the xfer..
how much are the lc/prado transfers offset? would it be too hard on the drive shaft ujs if it was to cross to centre? standard diff apart from 2" lift.
prado rear diff would solve that problem wouldn't it? can't afford that at mo with trying to sort the SAS.
Big wrote:..( not totally sure here ) but are centre rear and passengers drop to front.( no good for landcruiser and are also not as strong)
185 surf I'm SASing is passenger front but all earlier surfs & hiluxs are drivers front, which is why I'm changing transfer to get drivers front, for prado diff, but was hoping to get pto aswell.
Andrew 0272226292.
kbushnz
Re: Toyota Auto's
Post by kbushnz »
if you do the Prado transfer case (70 series) best to put the gear and spacer in before you fit it to the truck. As you practically pull it to bits. There is a thread on here with the gear install.
I can measure the off set of the Prado transfer case tomorrow when I get home from work...
Big
Re: Toyota Auto's
Post by Big »
Some Prado's have the same split case that has pto option on passenger side.. drive shafts are drivers side..BUT that is the LJ71,78 and might be KZj series also.. but I know some have the centre rear like hilux's and they wont have a pto option.. Im pretty sure..
Big
Re: Toyota Auto's
Post by Big »
O I forgot to mention I tried to find my post on lextreme and found the one I posted looking for the same list.. :shock: can't find it.. :( but is was like Jeeps, Mitsi, Toyota, Nissan etrc shared the same trans but with different internals and slight gearing changes but essentially the same auto, cut the tail off it and you could mount the transferbox to it no worries..
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
Big wrote:but I know some have the centre rear like hilux's and they wont have a pto option.. Im pretty sure..
typical aye! :evil:
kbushnz wrote:best to put the gear and spacer in before you fit it to the truck. As you practically pull it to bits.
ok. will look into it.
Andrew 0272226292.
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
can the pto drive get mounted either way? to the front bar OR to the rear for a forwards facing winch.
Andrew 0272226292.
mudlva
Re: Toyota Auto's
Post by mudlva »
mudsurfv6 wrote:can the pto drive get mounted either way? to the front bar OR to the rear for a forwards facing winch.
Yep just swap the output over
kbushnz
Re: Toyota Auto's
Post by kbushnz »
Yes you can swap the output over from coming out the front to coming out the rear, however you need to change some spacers over inside the PTO housing to get the gear to sit in the right place. Been there done that....
Or you could find a double output PTO unit, they do exists but are a bit rare...
Here is a thread I did about my mid mount winch in a KZJ78... The first page shows the transfer case and the gear install. viewtopic.php?f=18&t=25791
mudsurfv6
Re: Toyota Auto's
Post by mudsurfv6 »
kbushnz wrote:Here is a thread I did about my mid mount winch in a KZJ78... The first page shows the transfer case and the gear install. viewtopic.php?f=18&t=25791
have saved to favourites for quick reference.
Andrew 0272226292.
hyperlux
Re: Toyota Auto's
Post by hyperlux »
Hi Team, Interesting read. Just wondering if anyone could help me out out with the following. I am currently mating up an A340H auto to a Toyota 7MGE for my Hilux, have all of the wiring sorted except the transfer section. Any pointers or info ?
Cheers Brad
HYPERLUX
Cheers Brad
HYPERLUX
ChurchurDan
Re: Toyota Auto's
Post by ChurchurDan »
I have made one of them work. They are hydraulic shifted so you need the engine running to select 4wd, and there is a solenoid in there that needs to be powered when you move the lever to low range. The range select switch on the side of the transfer case can be used to get it working.
hyperlux
Re: Toyota Auto's
Post by hyperlux »
Thanks.
Cheers Brad
HYPERLUX
