Beam axle Hilux GVM
churchill
Beam axle Hilux GVM
Post by churchill »
Anyone know the gross vehicle weight (max all up weight) of a Hilux with beam axles?
Re: Beam axle Hilux GVM
Got a rego ??
Chuck into www.carjam.co.nz ;-)
mudlva
Post by mudlva »
Off hand
gvm 2700-2800kgs
mudlva wrote:Off hand
gvm 2700-2800kgs
Nah. Thats the weight of an 80 series ;-)
A quick look on trade me and then on carjam revealed this ^^^^^^^
mudlva
Post by mudlva »
gvm 2700-2800kgs
Done a google and gvm of between 2710kg to 2885kg depending on model etc so estimate was pretty good
bigstu
Post by bigstu »
My beam axle surf is 1800kg on the weighbridge full gas but no one in it
mudlva
Post by mudlva »
Crash bandicoot
Post by Crash bandicoot »
bigstu wrote:My beam axle surf is 1800kg on the weighbridge full gas but no one in it
So that'd be Tare Wieght, not Gross
churchill
Post by churchill »
gvm 2700-2800kgs
This ones the ticket, thanks.
churchill
Post by churchill »
mudlva wrote:http://www.toyota.com.au/hilux/features/performance/payloads
These look like current GVM's, I need ones for the older beam axle fronts. Thanks for the help.
bigstu
Post by bigstu »
Yes so shouldnt be hard to work out gross those other weights wouldnt be far off
prob 2700 - 2800
A single cab rated/marketed as 1 tonne plus 1700kg
=2700
A double cab would be same total but less payload due to the extra cab weight etc.
