I am selling my 1986/ Suzuki SJ413 Transfer Case which i stripped down and fitted about 6 months ago with the Trail Gear 6.5 to 1 reductions gears.
These gears give a 12% reduction in high range and 188% reduction in low range. Externally the transfer case is not modified so will just bolt up, i have the original SJ413 gears which i will include along with the printed manual.
The transfer case comes with standard Suzuki drive shaft flanges but i can also include the front and rear adapters to bolt up Hilux drive shafts for a bit extra.
I am now changing direction on my buggy so this transfer case is no longer required
PM if your interested
Happy to answer questions
happy to ship at your expense.
F/S SJ413 Transfer Case with 6.5 to 1 gears fitted
teamorange
- Driver/Navigator
teamorange
- Driver/Navigator
Re: F/S SJ413 Transfer Case with 6.5 to 1 gears fitted
Transfer case now sold however i still have the suzuki to hilux drive shaft flanges to allow you to run hilux drive shafts from your suzuki transfer case
Excellent quality item, with all screws/washers $80 for both of them, i am happy to ship at buyers expense
I will stick them on TM if no interest here
