speedo correction
ski
speedo correction
Post by ski »
Howdy I have a 1991 ,cruiser 1hz running 35 inch silver stones and my speedo is 20km out,truck is coming up for cert on suspension work and I was thinking about speedo what do you guys do to correct this ? running lockers so don,t want to change diff ratios etc ,any ideas???. Cheers.
Mattman
Re: speedo correction
Post by Mattman »
If its a cable driven speedo you can often change the gearing to correct it. If its electronic jaycar do a correction unit.
derk
Post by derk »
easiest way if you've got a bit of spare time in front of the computer is to make up a new label for the speedo on paint and print it out on some adhesive paper :D
ski
Post by ski »
Jesus I have enough trouble working out how to use my sky/// . Cheers.
imsohi
Post by imsohi »
Parrot and sons in Chch do a conversion unit if it is cable, i would ring them as they could prob sort out a elec one aswel. all we had to do was send them the difference in speeds ie GPS--->Atcual 20=25 50=58 70=83 100=116
They made up a unit and we installed was around the $300 mark
ski
Post by ski »
Thanks man ,I presume its cable being such and old truck. Cheers.
Use a gps ;-)
Have heard a couple of mechanics say that a gps is a legit speedo.
Not sure if tru, but cheap fix
Ashohman
Post by Ashohman »
i made ups some dyno labels and stuck them to the speedo just went for a drive with the gps and recorded what speeds were what cert man was happy with this ive got 50 60 70 80 90 100
churchill
Post by churchill »
These guys sell geared units that fit between your speedo cable and gearbox that can either speed up or slow down the cable to get the correct speed.
They reckon they have 50 ratios available(both up and down) and cost between $170-$250 depending on ratio.
http://www.robinsoninstruments.co.nz/ri_services.html
Mudde1
Post by Mudde1 »
skid wrote:Use a gps ;-)
Not True. GPS is not a legal speedo as it wont work in tunnels, deep cuttings etc.
Tony.
mudlva
Post by mudlva »
Got a reducer here
It was geared to suit 35s from ex31s
Screws onto the trans box outlet and then the speedo cable screws into the adaptor
Pretty easy
It was over a $100 if i remember
$50+courier if you are keen
Got to find it now .....
