TD42 Starter Motor Fix
Posted: Wed Aug 12, 2015 9:19 pm
by Dundaberg
Gidday all. So starter motor has decided to be lame. now to get it to start I have to belt the shit out of the starter solenoid as i turn the key to get it to click into life. Obviously im in for a clean out and maybe a rebuild. Any tips on how to strip the starter motor and where to get brushes etc from?
Cheers, Brandon.
Re: TD42 Starter Motor Fix
Posted: Thu Aug 13, 2015 11:50 am
by nuts
SOLENOIDS ARE A SEALED UNIT AS FAR AS REKITIING THEM UNLESS YOU KNOW SOMEONE WHO HAS HAD A SUCSESSFUL GO AT OPENING ONE AND DOING IT THEY ARE A REPLACE THE WHOLE SOLENIOD JOB
Posted: Thu Aug 13, 2015 3:00 pm
by Dundaberg
Ah rito. Cheers for that
Posted: Thu Aug 13, 2015 5:52 pm
by Dundaberg
Ordered the parts to rebuild the starter today, hopfully be here tomorrow. partys costing around $250ish I think.
Posted: Fri Aug 14, 2015 5:17 pm
by Crash bandicoot
solenoids aren't a sealed unit you can dismantle them, its the coil on the end that would be iffy at best, but normally i have found with the 12volt and 24 volt hitachi's is the brushes or there connections and on the bosch units the brass bushes on the spindle wear out causing the motor shaft windings to touch the housing creating a short.
