Hey Guys, Im about to undergo some maintenance on my 96 Challenger. Including replacing the Radiator, Water Pump, Thermostat, and Timing Chain (kit), Rocker Head Gasket. Just a quick question, it was suggested that I should do the oil pump too, is this worth doing? Im not entirely convinced??
Any other precautionary stuff I should look at doing while the 'lids off'??
Any advice would be great!
4M40 Maintenance
Re: 4M40 Maintenance
i would at least inspect the oil pump but i would probably rebuild it myself if you are going as far as you are already
my 4wd is not a truck
replacing the oil pump as part of a service is bit unheard of unless you've got low oil pressure problems or if there is a known problem with the pump on those engines, if you've got low oil pressure problems you might have some more major issues to deal with
