So for the engine swap in the Terrano it looks pretty likely that I will have to swap the air con compressors, I'm picking that the fittings will different so I was wondering if anyone knew if it was possible to join the hoses with barbed brass joiners and good hose clamps?
Also while I'm at it does anyone know if the TD27 and QD32 compressors would be the same? It seems a lot of other bits are, and likely easier to find a TD27 one than a QD32
Cheers, Clive
Air Con Hoses?
Air Con Hoses?
- evolution02
Re: Air Con Hoses?
No don't try and join the aircon hoses your self. They will need to be made up by an aircon shop for you.
I do aircon and hose clamps on a joiner won't work
As for the pumps I'm not sure if they're same but would think they would be much different
Re: Air Con Hoses?
Thought that would be the case. Kindof hoping that Mr nissan might have used the same fittings around similar years so I don't have to get hoses made up
