ln106 1kz conversion front drive shaft to short
matt303
Post by matt303 »
hey guys, have just done a 1kz conversion out of kzn30 into ln106 and the front drive shaft is 70mm to short, are there any factory longer drive shafts or do i have to lengthen it? cheers
Toyota Hilux LN106
commy v6
3inch efs lift
2inch body lift
front lokka
5.29 trail creeper diffs
longfield chromoly cvs and axles
shimmed LSD rear(basically locked)
36 silverstones
4terrain clutch
runva winch
uhf 5W radio
120w light bar
2.5inch exhaust
kaupoi
Re: ln106 1kz conversion front drive shaft to short
Post by kaupoi »
Just make one using SHS box.
Smurf
Post by Smurf »
Are you using the 106 driveshaft or the Surf one?
4X4LUX
Post by 4X4LUX »
Surf one is about 50mm longer than ln106.
