Land cruiser 80 man or auto box wtb
Wanted, truck is an auto, trans is getting hadit, so undecided if I'll put a manual in or keep it auto, if you have a good auto or manual box or just a conversion kit for an 80 series let me know. It currently has an a442f non electronic trans in it
- mudlva
Re: Land cruiser 80 man or auto box wtb
A lc73/4 gearbox should bolt up.
Will need custom cross member and altered d.s.
Getting a clutch pedal for a 80 will be rear as.
Possible convert a 70 pedal and cylinder to suit.
Will become parttime as well so will need f.w.hubs
mudlva wrote:A lc73/4 gearbox should bolt up.
To add to that, the cluth pedal and trans tunnel trim from a manual early 80 are obsolete, so only way to get them is if local Toyota has stock
Although I did find out that if the vehicle came out as a manual, you can do an auto -> manual conversion without a Cert providing you dont touch the brake pedal.
Who knew Prados could fly?
- mudlva
Try ebay for pedal box.
The yanks have shit loads of vc80s and lots in manaul
Just have to get round the left steer side problem
Hey guys, yeah I'm struggling to find s manual gearbox at all, so might have to rebuild the auto
- mudlva
So you cant find a 5spd out of a bj or hj 73/4 lc then?
Got two sitting out back shed right now
Must be loads down your ways shorely
Unsure about the engine output but at a guess should be fine spline so clutch should all work
Just need to sort pedal box as stated above
this fella says he has a manual conversion..
http://www.trademe.co.nz/Members/Listin ... er=3515084 check it out.. might be worth a look
- mudlva
Cullum if you do go this way and need it collectec etc let me know.
Im about an hr drive away but for cost of fuel will be able to sort it out for you if required
Hey cheers just hit the guy up, pretty cheap eh! Haven't seen a kit like this b4. I'll keep you in mind, cheers
Found, bought
