Rough idle and hesitation... HELP!
Posted: Mon Aug 31, 2015 11:10 pm
Hey guys.
Car: 1991 Escudo G16B 16v
Resent maintenance: Headgasket, timing belt, oil change (all done by previous owner) , spark plugs, one spark plug lead and coolant change.
Bought the escudo a few months back and everything was fine until I had a problem with high idle.
Took the throttle body off and cleaned the IAC which helped for a bit but now its back with bigger problems.
The idle is high for a few seconds when cold then slowly drops to around 1000rpm at which it starts to misfire and run rough. When i take the thing for a drive it hesitates quite badly but not in first and sometimes second. I will put my foot on the gas and nothing will happen or it will jerk slightly then all of a sudden get power and rev up.
I've also cleaned the egr valve to no avail and checked the timing which was spot on.
Quite alot of steam comes from the exhaust on cold mornings but seems to go away when warm. (hoping its not a cracked head...)
Also noticed a large crack in the exhaust manifold (above the o2 sensor) hence my other thread.
Could this be my problem? o2 sensor getting wrong readings?
Going to do a leak down test on the engine next week.
Any help is much appreciated.
