1kz help many problems and im stumped
Posted: Wed Sep 02, 2015 8:17 pm
hey guys, so I have just put 1kz into ln106 along with mechanical injector pump and new flowed turbo and having a few issues with it, its a little hard to start cold takes about 2-3 cranks to start, and rough idle for 10sec and a miss and then comes right, but when hot it won't start at all unless i prime it while turning it over and it will eventually start. second issue is i have real high oil pressure, past 80psi at 2-2500rpm and is at point its forcing oil past turbo seals. I have check pressure relief valves and 2 different brand oil filters, I have ended up cutting 2 coils off oil valve spring, it now holds about 45psi warm now. I have been over all basics and has me stumped what it all could be. cheers
