qd3.2 refusing to start
A place where Useful information on makes of 4wd is stored by Tech Authors.
Moderators: Steve_t647, Tech Authors
Mrferal
Stropper
Post by Mrferal »
Gidaye, looking for some help on this, I can get fuel up to the diesel pump, but from the diesel pump to the injectors there is absolutely nothing
It just decided one very cold morning that it didn't want to go.
Previous day was towing a tandem trailer with 1½ ton of coal on
Previously had only refused to go on a really cold morning, minus 3°, got the AA in and he squirted some ether and boosted the battery and away out went
A couple of previous owners put a switch in to turn the speedo off but this also makes the engine light to come on so leave it switched on
Can anyone help please?
fh2014
Re: qd3.2 refusing to start
Post by fh2014 »
tried hand priming hard while someones turning it over?
Crash bandicoot
Post by Crash bandicoot »
you will need to check that the fuel stop solenoid wire is still connected to the back of the pump. '
you can also just hot wire it to the + battery terminal and should here it click. if it does, leave it on and start the truck.
failing that, i guess its a post 96 3.2?
Return to “Tech Section/Library”
