185 supercharged 3.4 V6 surf, prado diff housing, surf hubs, front Lokka, 70 series tie rod & drag link, 80 series steering box, 2" suspension lift, 130 rear panhard cut down, 35s.
use steering damper off what? 70 prado? 70 lc? leaf hilux? ??? got to add mount to diff.
what breed steering damper are people using? was thinking of using Tough Dog adjustable or RTC.
185 SAS steering damper?
Andrew 0272226292.
Andrew 0272226292.
Re: 185 SAS steering damper?
if your using a LC70 tierod the damper will bolt straight into the drivers side balljoint you'll only have to add a mount to the chassis if there isn't already one there. Any heavy duty damper should suit your 35" tyres try and avoid the lighter constructed dampers, I've used efs extreme ones before and liked them they are heavy duty, long lasting and good at burning a big hole in your pocket but still good value for what you get
Good post Derk.
Mudsurf how come you are running surf hubs on the Prado axle?
Mattman wrote:Good post Derk.
Widen the front track also hilux freewheel hubs bolt straight on.
bigstu wrote:Widen the front track also hilux freewheel hubs bolt straight on.
plus got the prado diff housing off a mate and already had hilux diffs sitting here for the rest. cheapest option.
Andrew 0272226292.
Andrew 0272226292.
