Ln106 wandering steering
Mattshilux
Post by Mattshilux »
My ln106 is suffering from some wandering steering have already tried adjusting the drag link what other options are there before going and spending a heap of money
Smurf
Re: Ln106 wandering steering
Post by Smurf »
king pins, Tie rod ends, draglink ends, leaf spring bushes, u bolts, wheel bearings. front diff torque rod/anti tramp rod, loose wheel nuts.
Play in any of these can potentially affect your steering
Mattshilux
Smurf wrote:king pins, Tie rod ends, draglink ends, leaf spring bushes, u bolts, wheel bearings. front diff torque rod/anti tramp rod, loose wheel nuts.
Cheers!
nzlux
Post by nzlux »
Have you checked for play in the J arm?
J_Dub
Post by J_Dub »
Power steering . there's a screw to adjust the slop in the steering wheel
Mattshilux
J_Dub wrote:Power steering . there's a screw to adjust the slop in the steering wheel
how do i get to this screw?
derk
Post by derk »
its on top of the steering box don't wind it up too tight or it'll be like driving down railway tracks :D its only to take the lash out of the worm drive in the steering box
J_Dub
Post by J_Dub »
Yep it has a lock nut and a flat screw head, relieve the lock nut and if I remember right it only needs half a turn, turn it enough so there's no slop in your steering. Ie when you move steering wheel side to side while truck is stationary there should be no play before wheels respond
