Got Some More Optima Batteries
Posted: Thu Sep 17, 2015 9:00 pm
by 4wdstuff
Hi,
As the title says I have got some more batteries as per below.
Optima 8004-003 Red Top Starting AGM Battery 34/78 CCA 800 amps Can do these for $350 plus post.
Optima 8012-021 Yellow Top Deep Cycle & Starting AGM Battery D34, CCA 750 amps. Can do these for $425 plus post.
Optima 8012-045 Yellow Top Deep Cycle & Starting AGM Battery D34/78, CCA 750 amps. Can do these for $435 plus post.
Optima 8051-160 YellowTop Deep Cycle & Starting AGM Battery D31A, CCA 900 amps. Can do these for $525 plus post
Post to Auck $10, Lower Nth Is $15 and Sth Is $25.
If interested send me an email on
4wdstufftim@gmail.comCheers
Tim
Re: Got Some More Optima Batteries
Posted: Sun Sep 20, 2015 11:05 pm
by 4wdstuff
Bump
Posted: Mon Sep 21, 2015 10:14 am
by mike
I've had optima batteries for ten years in my truck now, the same ones. Multiple times flat (both of them, usual story, lights on slow drain oops), used in anger for long winches, winch comps etc. Both going strong but obviously not as good as when I got them but still pretty bloody awesome. It would take a bit of persuasion for me to go to something else
Just thought I would put that out there if you thought the price of these things are expensive. Over ten years it works out bloody cheap!
Posted: Mon Sep 21, 2015 1:03 pm
by fh2014
what one would you recommend for a 2.7td terrano with the usual accessories, 9500 winch and spot lights?
Posted: Mon Sep 21, 2015 8:07 pm
by 4wdstuff
Yellow top if using a winch, red is more just for starting with light electrical loads.
Bigger the better if it will fit. If doing alot of winching 2 is even better.
Only difference between the D34 and D34/78 is the D34/78 has a couple of extra terminals on the side for connecting to.
Tim
Posted: Fri Sep 25, 2015 1:59 pm
by 4wdstuff
Bump
Tim
Posted: Tue Oct 13, 2015 12:39 pm
by 4wdstuff
Bump
Tim
Posted: Thu Oct 29, 2015 7:31 pm
by BlakeNZ
wow, these are really sharp prices.
Posted: Mon Nov 16, 2015 4:51 pm
by 4wdstuff
Posted: Fri Apr 08, 2016 11:07 am
by 4wdstuff
Bump
Tim
Posted: Wed Apr 13, 2016 5:15 pm
by Big
finally looking at another one Tim.. got any deals going ? big is better
Posted: Wed Apr 13, 2016 9:56 pm
by 4wdstuff
Hi Keri,
Sold out of the big ones at the moment, getting some more in next shipment.
Will send you a PM
Tim
Posted: Sat Jul 30, 2016 10:16 pm
by 4wdstuff
Posted: Sun Jul 31, 2016 6:53 am
by MihiT
Any blueys? I think it was M34 I was looking at
Posted: Sun Jul 31, 2016 10:51 am
by 4wdstuff
Sorry only Yellows, any particular reason you want Blues
Tim
Posted: Sat Aug 13, 2016 6:59 pm
by Crawlerer79
Hi Tim,
When will the Red Top batteries be back in stock.
It's nearly time for my Landies battery to be replaced
Tim
