Turbo timer for 1KZ ???
allys551
Post by allys551 »
Do i need a turbo timer for my kjz78 with a 1KZ motor i was gonna install a Pyro gauge, but was wondering about the need for a turbo timer aswell?
oldblue
Re: Turbo timer for 1KZ ???
Post by oldblue »
Its one of those questions that every person will give you a different answer. Cheaper to leave motor idling for a few minutes before turning off key. They can get you into trouble if not used correctly.
Smurf
Post by Smurf »
oldblue wrote:Its one of those questions that every person will give you a different answer. Cheaper to leave motor idling for a few minutes before turning off key. They can get you into trouble if not used correctly.
I'd agree with this.
By the time you leave the motorway/open road and then quietly drive down your residential street to your driveway you aren't putting any load on the motor and it has a chance to cool a bit if needed.
allys551
Post by allys551 »
thanks @Smurf @oldblue - good advise appreciate the info. cheers
