LN61 2LT GEARBOX
yourlocalheadhunter
LN61 2LT GEARBOX
Post by yourlocalheadhunter »
Will a ln61 4x4 gearbox from a 2lt fit a ln106 with a 2.8?
Cheers guys
Smurf
Re: LN61 2LT GEARBOX
Post by Smurf »
It will bolt to your motor and should take your drive shafts, gear levers are in a slightly different location and you may need to grind/cut the tunnel a bit to get the levers to work. Yours has a G52 in it I believe.
yourlocalheadhunter
Thanks, So with a bench seat it may not work depending which way they levers are more forward?
Smurf
Post by Smurf »
Gear levers on the Surf box sit further back. If you google the boxes you will see the difference.
W56 is the Surf
G52 is the Hilux
yourlocalheadhunter
Thanks mate
