LN61 2LT GEARBOX
Posted: Tue Sep 29, 2015 8:29 pm
by yourlocalheadhunter
Will a ln61 4x4 gearbox from a 2lt fit a ln106 with a 2.8?
Cheers guys
Re: LN61 2LT GEARBOX
Posted: Tue Sep 29, 2015 8:36 pm
by Smurf
It will bolt to your motor and should take your drive shafts, gear levers are in a slightly different location and you may need to grind/cut the tunnel a bit to get the levers to work. Yours has a G52 in it I believe.
Posted: Tue Sep 29, 2015 8:39 pm
Thanks, So with a bench seat it may not work depending which way they levers are more forward?
Posted: Tue Sep 29, 2015 8:48 pm
by Smurf
Gear levers on the Surf box sit further back. If you google the boxes you will see the difference.
W56 is the Surf
G52 is the Hilux
Posted: Tue Sep 29, 2015 8:53 pm
Thanks mate
