One of my CVS is worn
I'm going to replace both,need CVS for abs model if there's a difference
Anybody know what genuine CVS are worth or a good quality aftermarket brand?
80 series cv
Re: 80 series cv
Lchundy wrote:Anybody know what genuine CVS are worth or a good quality aftermarket brand?
factory 80 series CV's are relatively strong but with those 37" Treps some chromoly Longfield™or RCV's™ would be a worthwhile purchase
Re: 80 series cv
Yeah rcv make some cool stuff
I'll try get some chromoly cvs think Tim sells them if not I'll go genuine because i need them asap.
Be awesome to get the chromoly axle to but can't afford it
- mudlva
Re: 80 series cv
Go oe
CM will wear out on a dd. The metal is softer so wears faster than std cvs
Re: 80 series cv
If it part time then it'll be mint... And I need to get ya number off ya mudluva so I can come down and grab that spool off ya
- mudlva
Re: 80 series cv
Part time 4x4 CM all the way
021599519
I'm generally home buried in shed trying to get my buggy going. ....
021599519
Re: 80 series cv
Thought about part time
Chunky mud tyres rwd on wet roads bit of grunt can be dodgy specially those shiny patches.
I'll also loose my abs
Disadvantage of chromoly is they where out quicker because metal softer?
Would the advantage be there stronger with impact like when you drop a spinning wheel?
Advantage of toyota cvs is they have 2 year warranty and there's 3 dealers within 10 mins of home
Probably go genuine because you can order in morning pick up afternoon as I need asap so can get truck going.
End of the day it's got a hilux front diff so only so much you can do before that gives way
- mudlva
Re: 80 series cv
If you go oe then change to cm let me know as i will purchase your oe cvs off you.
My dd is clunking on lock so will be in need of new cvs.
You can buy adapters off marks in aussy to move the abs from cv side to hub side.
Imho i would run part time with cm cvs. Just to expensive to ruin by std wear and tear.
Re: 80 series cv
Lchundy wrote:Thought about part time
slow down and drive to the conditions mate its a tall, high COG 50 ton cruiser on big tyres not a sports car
Re: 80 series cv
Yep realise that I ain't no speed demon on road and drive the truck knowing what it is
Extreme mud tyres on wet roads are like racing slicks so full time 4wd helps keep it all in line
Re: 80 series cv
Lchundy wrote:Yep realise that I ain't no speed demon on road and drive the truck knowing what it is![]()
Silverstones?
Who knew Prados could fly?
