1KZTE Overboost?
Posted: Sun Oct 11, 2015 5:29 pm
by Harveyp
Hi there everyone.
I have recently installed a boost gauge in my 1998 Hilux Surf Limited due to the fact I have felt a loss of power. I notice the boost gauge will shoot up to 15psi full boost, then drop back to 11psi and flatten out. Is this a sign of over boost?
Re: 1KZTE Overboost?
Posted: Sun Oct 11, 2015 5:59 pm
by Harveyp
To add to that, I just did a fault code check, and it has come up with a clashing check light and O/D light.
Posted: Sun Oct 11, 2015 8:27 pm
by Crash bandicoot
Harveyp wrote:To add to that, I just did a fault code check, and it has come up with a clashing check light and O/D light.
if they are both on then you most likley have a fualt with the engine and the trans...in this case could be the TPS since both the engine and the trans use it.
Posted: Mon Oct 12, 2015 9:01 am
by oldblue
Is the speedo still working?
Posted: Mon Oct 12, 2015 8:34 pm
by Harveyp
Speedo is still working, the fault code flashing was between engine check and O/D Light, one goes on the other goes off, very fast (0.25 seconds)
Posted: Sat Oct 17, 2015 2:44 pm
by floatingkiwi
Where do you live Harvey? I'm in Taupo with a Techstream to pull and clear all those codes and have a look at the sensor values real time.
Do a google search and you'll find out how to read your engine codes by joining up the diagnostic connectors in your engine bay.
