Not for me
Whats the usual things to look out for, did these have head issues like the non intercooled ones, any areas for rust etc?
thanks
Buying a KZN185 Surf Hilux
Re: Buying a LN185 Surf Hilux
Never heard of a LN185 surf. Please enlighten, as to year, and engine?
BlakeNZ wrote:Never heard of a LN185 surf. Please enlighten, as to year, and engine?
Ha, typing to many things at once. intercooled 1KZ Surf
Re: Buying a KZN185 Surf Hilux
there is plenty of anecdotal evidence to suggest that the intercooled ones do much higher mileage before cracking heads. I have now seen 5 that have done 500,000kms without doing the head. However, there are also a number of Prados around(same intercooled 1KZ motor) that HAVE cracked their heads, so it can be a bit of a lottery. What i will say, is that the intercooler lowers the EGTs by quite a lot when under full power. I'd also speculate that nearly every single intercooled 1kz that cracked a head, did NOT have an aftermarket down pipe, and exhaust.
From the 185s that i have seen (and owned a RZN185) rust hasn't been a big factor in the 185 series Surfs at all yet, but (by logical extension) can suffer in the usual places if used a lot on beaches or used to launch boats. A thorough pre purchase inspection is invaluable. Make sure you have a look at the roof rails, or roof rack if it has one(specifically the mounts/bases) as they can provide an entry/starting point for rust( you will see paint starting to bubble if there is an issue.) this is generally a cheap and long term fix though.
also check to see if the load security d shackles in the rear luggage compartment are rusty- this often means that the truck has been used by sea divers, snorkellers, or fishermen, and the wetsuits/waders have been chucked in the back.
The intercooled one have held up in value(plenty for sale at around $11-14K still), so if they intend to do a lot of towing, just make sure they look at other options for similar money(think landcruiser and patrol/safari).
Ergonomically they are real practical and easy to live with. The back seats fold up/down to make a flat sleeping/storage area, tall enough for big fellas even. IMO the best sleeping platform 4wd wagon.
There is plenty of ideas on this forum,( and others) to seriously help delay any head cracking.
read here.
viewtopic.php?f=22&t=43160&p=439349&hilit=+1kz#p439349
and here
http://www.toyotasurf.asn.au/forum/view ... hp?t=20880
and a guy in Palmy has a jig, so can supply bolt on dump pipe and exhaust system for KZN185s (3" diameter).
you also want to contact forum member "Zed", he knows lots about lots, including lots about the 1KZ.
read here.
and here
Couldn't be bothered reading all that, but 2 known issues are the shit house quality ball joints on the IFS and a weak as shit centre diff unit. The surf is selectable for AWD so it may not have the centre diff issue as bad as 90 series Prado's (which share the same platform).
