best place to get navara gearbox kit from
best place to get a navara gearbox kit from? 1990, manual
Re: best place to get navara gearbox kit from
yes - bearing kit
about 500 dollars of ebay in aussie, may have to pull your box apart first though make sure it hasnt damaged the hard facing on the shafts as replacement shafts are not part of it.
Seems expensive? $180 for a bearing kit off Zargo on trademe
rxsmiddy wrote:Seems expensive? $180 for a bearing kit off Zargo on trademe
you get what you pay for.
there's a reason they charge 800 odd dollars for an exchange rebuild with a warrantee.
like people buying these el cheapo aluminium tanked radiators and wonder why they blow the tanks off the end.
just sayin, your choice.
Yep all good.
How do I tell witch gearbox I have in mine? Obviously manual, has a td27t in it - are the gearboxes different? Was originally td27 - is the earlyer engine with the bolt on intake into the turbo
what model and year is the vehicle.
must be a bit more than just bearings and seals in the aussie kits if they are flogging them off for 500
derk wrote:must be a bit more than just bearings and seals in the aussie kits if they are flogging them off for 500
exactly gaskets, pins, bushes, shift knuckle etc. proper rebuild kit
Crash bandicoot wrote:what model and year is the vehicle.
1990 Nissan Datsun pickup
