ok dumb arse question but as I just brought a 93 safari im not sure if its been lifted, i mean how do ya tell? soooo... I have measured from the roof gutter to the center of the rear wheel, 1350mm
can you lot that have std height measure yours and post up ta? same if you have a 50mm lift, tell me what ya gutter to center of wheel is
has the safari been lifted?
Re: has the safari been lifted?
the proper measurement is from the top of the gaurd to wheel centre and is how most people will measure it, might pay to get that and put it up.dangerous wrote:ok dumb arse question but as I just brought a 93 safari im not sure if its been lifted, i mean how do ya tell? soooo... I have measured from the roof gutter to the center of the rear wheel, 1350mm
ok... measuring tape butted up under the flear or guard to center is.... 505mm (rear wheel with the factory extra flear)
just figgered it was easier to hook the tape over the gutter
mine up 75 mm 1400 between gutter and rear wheel centre
