31x11.5
stan
31x11.5
Post by stan »
does any1 know if they can get or have seen any tyres either 31x11.5 or even 30x11.5...i have 32x11.5 and are really bit tall geared :?
doddzee
Is Doddgee
Post by doddzee »
MWB V8 Safari Ute
stan
Post by stan »
do you know how they wear on the road obviously designed for off road but i do bit of both..im running 15x10 rims on hilux and 32x11.5x15 goodyear wranglers but slightly rub and lost lot of power also have turbo on 2.8 which helped :?
Smurf
Post by Smurf »
have you considered changing your diff ratios to help bring your gearing back? rather then replace tyres?
stan
Post by stan »
:? yeah did think of that but what ratio..i jacked back end up and done 1 rotation of wheel which was 4.5 turns on drive shaft so ratio now i think is 4:5:1 does that sound right..id plate on firewall does not have axle number for some reason just has g52
Smurf
Post by Smurf »
G52 is your gearbox. and if your rotations of d/shaft are correct then you have 4.5 ratio diffs too. To improve diff ratios you need to go to 4.88 but have heard that they are a weaker diff as the teeth are thinner.
I have 4.88s in my Surf and running 33s. No worries...yet....
Return to “Tyres”
