TD42 Safe boost numbers
tuckertrucker
Post by tuckertrucker »
Hi guys and gals,
what would be the max safe boost numbers for a 92 Silvertop TD42? I was hoping for 15 maybe 17, also how to compensate for boost so Im not running lean? Do I have to get a boost compensator or can I just dial it up a bit or something?
Twodiffs
Re: TD42 Safe boost numbers
Post by Twodiffs »
It will handle that boost easily and some......depends whether your turbo will do it?.
Twodiffs
Post by Twodiffs »
Fit an egt gauge and probe, get it tuned properly and you should be good. You can fit a boost tap and adjust up or down slightly but it's all proportional to the fuel going in.
tweake
Post by tweake »
what turbo?
its down to what turbo you have and how high can it go before going horribly inefficient.
a boost comp fitted to the pump and set up costs mine was around $2500, bit of a pain to remove and reinstall too, :D
