shock length
brakes-shocks-lockers-etc
yourlocalheadhunter
shock length
Post by yourlocalheadhunter »
I have a ln106 hilux with 2" body lift and have just fitted a 2" suspension lift. Im hoping to fit 2" extended shackles also.
I have shocks that came with my kit but i feel they will restrict travel off road, Im hoping some can give me the best to work out what length shocks im going need.
Also looking into inverting rears for more articulation
mudlva
Re: shock length
Post by mudlva »
After installing all the new suspention components
Support vehicle on the chassis with a wheel off to allow easy measuring.
Use jack to take weight of axle and remove shock
Release jack and lower axle to allow springs to full travel
This will be maximum shock extention
Now jack up axle so it takes load off chassis.
The target is to fully compress spring so the bump stop is taking load
You may need to support axle at top of jack stroke and reset jack as normally it will not start to bottom out until the other wheel starts to lift off the ground.
Once you have the bump stop taking lloa this is the fully compressed stroke.
Now that you have the two measurement search for a shock that suits.
Remember that the new shock on minimum stroke can not be longer than your measurement. If it is then on bottom out stroke the shock mounts will take load and rip them off
yourlocalheadhunter
Re: shock length
If leaf spring was to touch bump stop it would be 335mm. With chassis jacked up extended drop is roughly 555mm.
This is with no shocks in the vechile also no tourqe arm? Will that make a difference?
mudlva
Re: shock length
Post by mudlva »
Torque arm stops diff from rolling so no bearing on shocks
So what you are after is a shock that is 330mm compressed and extends to 555mm or there abouts
Extended lenght is nominal.
To short and will hold axle up a little. No problem
To long and spring will fully extend. No problem
If the compressed lenght more than 330mm then the chassis mount will need to be altered acordingly
Checkerhead
Re: shock length
Post by Checkerhead »
I reality the torque arm actually does limit the down travel a bit, on the drivers side at least.
yourlocalheadhunter
Re: shock length
the shocks that came with the lift kit measure front 348mm compressed and extended 484mm. Im curious how they work these measurements out though as it will restrict the suspension badly if i fit these?
Smurf
Re: shock length
Post by Smurf »
yourlocalheadhunter wrote:the shocks that came with the lift kit measure front 348mm compressed and extended 484mm. Im curious how they work these measurements out though as it will restrict the suspension badly if i fit these?
The shock compression length is too long and you risk the chance of bottoming out your suspension and damaging the shock as it won't compress short enough to match your suspension compression. Results in a dead shock. You could space your bump stops down 20mm to match the shock compression.
You will also lose some of your suspension droop as the shock is shorter than what your suspension can extend to, Being too short on extension is not as damaging to your shock but way less than ideal.
Having said that, if your 4wd never left the road the shocks you have would be ok. But if you have to go through a certification you will be failed on your shock lengths.
My advise, buy the correct shocks to match your suspension.
yourlocalheadhunter
Re: shock length
Cheers for all the replys,
Main reason for my lift is i do most weekend go offroad through tracks and bush.
I have emailed the company as you say these shocks are no good to me so im looking for a part refund so i can hunt down some thatll work.
